a burning question on making a ramp with scan features
I wanted to make a rate-tunable ramp signal which can be fed to the elec-device via analog output of DAQ board. I tried a simple one, and it seems working. Ramp starts from the set values and stops when it reaches the max set, this is all right, but how can I make it automatically initialize itself and starts over again for the same range? any help would be really appreciated!!!
Regards
(3,367 Views)
You could put your entire application in a while loop. If you explain your code, we should be able to help you better.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,361 Views)
Hi Adnan,
Thank you very much for your notice:-)
If you look at the vi, what does it do is: it generates increasing numbers from 11000 to 38800 with certain rate, I can change the rate just by changing the divider value. and these numbers can be converted to U16, so that I can fed my Aout.vi which only recognize such format. Aout.vi is D/A converter which gives you voltage ramp signal at the end, this part is not included in the diagram. If I only use the loop alone,what I got at the U16 terminal is a sawtooth signal with amplititue changing from 0 to 65536 continuously. This is already a ramp with scan, ramp range is 0~65536, and each sawtooth is one scan.  Problems I have in this case are:
1, the ramp range, I do not need 0~65536 but something like 11000~3880, and if possible with a slection so that I can change what range i needed.
2, it would be perfect if I can set the number of scans (or number of tooth shape in sawtooth wave, please refer atttached figure). I think its quite possible, and there are lot of other ways to do the same the job, I just could not figure out how to do it at the moment. Thank you very much in advance!
(3,343 Views)
Attached is the another code, which does the same work but much simpler. problem still remains as described above:-(
(3,319 Views)
