Multifunction DAQ
Program hangs when using 2 USB-6008 DAQ's for analog input
I am attempting to utilize two USB-6008 multi function Daqs to obtain continuous simple analog input waveforms. My initial program worked with 1 USB-6008 but hangs after a few sample cycles when I have two USB-6008's providing input. I have attempted creating a simple VI with just the 2 USB-6008's with only graphical indicators and still have the same results (using 4 analog inputs RSE from each DAQ). The only way in which I can get them to function is to use on demand sampling, which is not as desireable for my application. This strikes me as a buffering problem but I am unsure as I recieve no errors, the computer just hangs perpetually. Any guidance on where my error may be or how to resolve this problem would be greatly appreciated.
(3,209 Views)
Post your VI or atleast the Block diagram of it.
A hint: since you say continous acqiusition for both cards, Keep the acquisition code of each card in a seperate while loop( have 2 seperate acquisition loops in the same VI)
(3,192 Views)
Well, your hint was the Key and there is no need for a posting of the VI. I had placed the boards into individual while loops, but their respective signals were routed outside of the while loop to different tasks. I placed all of the associated code for each of the aquisition units into the same loop and the aquisition unit and everything runs beautifully now. Thank you for the Hint!!
(3,184 Views)
