Programatically change port and line
Good afternoon,
I am trying to figure out how to programatically change the port and line setting depending on a predefined array.
(3,226 Views)
The lines/physical channels input will accept a string.  You'll get a coercion dot but it works just fine.
--Using LV8.2, 8.6, 2009, 2012--
(3,207 Views)
You could use a multiple case, case structure with different versions of that DAQmx Create Virtual Channel.
Depending on how many configurations you need, make that many cases and let it determine which virtual channel, with different port and lines, is used.
CLD Certified
(3,187 Views)
