‎03-25-2010 04:19 PM
I am new to this stuff, so if I show ignorance, I appologize. I would like to adjust the programmable gain on the DAQCard 1200. How can I do this. I have labview 6i. Is there something I have to edit with the card properties in the "measurement and automation" program. I was reading the users manual and it gave a table of gain settings I could set it to. I would like to set it to gain setting 5.
Thanks for any help you can provide,
Chris
‎03-26-2010 01:14 AM
The DAQmx driver automatically selects the gain for an acquisition when the input range is specified.
In other words : the gain is defined indirectly by the range (max and min) of the signal. See here for examples and more details.
‎03-26-2010
01:35 AM
- last edited on
‎05-02-2026
03:15 PM
by
Content Cleaner
I forget to mention that you will find the device gain - range table on page A-1 of the DAQCard-1200 user manual.
‎03-26-2010
04:04 PM
- last edited on
‎05-02-2026
03:16 PM
by
Content Cleaner
JB's absolutely right that it is set based on the input range you specify in software. For example if a card has a maximum input of 10V, and you specify a maximum signal of 5V, it will automatically choose the 2x gain (if it exists for that card) so it can have the most precise measurements.
