Pulse width measurement
With 8.5, I don't think there is anything you can do. the dll has been completely rewritten. In my old post, I was refering to an older VI that was much different internally. In that one, there was a for loop and it was passed an array of measurement types. The array could be modified to skip some of the tests. That option no longer exists.
Message 11 of 12
(932 Views)
Ok thanks for your response.  For a work around, i took sub sections of the waveform to seperate the two pulses, swapped them round and then appended them together again so i could use the pulse measurements vi to measure both pulse widths.
Message 12 of 12
(927 Views)
