03-27-2007 10:45 AM
03-28-2007
03:32 PM
- last edited on
07-15-2025
12:41 PM
by
Content Cleaner
The first thing to know is which driver you are using, DAQmx or Traditional DAQ. If you are using DAQmx, have you tried autocalibrating the card in Measurement and Automation Explorer (MAX). If you do that and see the same beahviour, then we should use the DAQ Diagnostic utility. This only works if you have DAQmx installed and is located at the following link. If you are using Traditional DAQ, then use the E series Diagnostic utility linked on this page. Let me know what kind of report those diagnostics give and we will solve the problem from there.
DAQ Diagnostic Utility
Have a great day,
Michael D
Applications Engineering
Message Edited by MickeyD on 03-28-2007 03:33 PM
