Read cold junction temperature
Is there a way to monitor the cold junction temperature on the 9213 module using Application Explorer? I am using NiDAQ V 9.6
(4,948 Views)
I think it is possible, I've used SCXI 1112 and reading CJC channel was very much possible there (you need to use 'SC1Mod1/_cjtemp0:7' as physical channel name to read all eight CJC channels in SCXI-1112).
I simulated 9213 and tried using 'Dev2/_cjtemp', I think this will work. Find attached VI.
I also found an example here, this might be interesting to you.
One more link here very specific to your query.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,921 Views)
I got it...
In order to access the internal channels of a DAQ card you need to do select 'Internal Channels' in the 'I/O Name Filtering' option'.
Select Internal Channels
(4,920 Views)
Thanks for the reply. Unfortunately, the I/O filtering option only appears to be available in LabView and my application does not use Labview. I can't see it in MAX. I have tried to create a virtual channel but the only physical channels I can see are the thermocouple inputs. There is no option to select internal channels.
Its beginning to look as if these modules are not suitable for my application 😞
(4,907 Views)
Ohh yeah, you mentioned it in the first post (using Application Explorer)... but I dint realize that you meant to say 'Measurement and Automation Explorer'...
Any specific reason that you want to create and use virtual channels, because I beleive using low level DAQmx function VIs are much powerful and flexible...
(4,901 Views)
