Reading -2 to -18 volts Analog Input
Dear Friends,
We are using PCI-6221 for data acquisition which is having voltage input range of +-10 Volts.
Recently we had a requirement of connecting new type of sensors with output voltage range of -2 to -18 volts.
Is there a way to connect this input the 6221 card?
Also, Is there any other DAQ Card available for this type of input range?
Shourya
(3,725 Views)
In order to bring the voltage level into the range that the board can measure, you must use an attenuator. A voltage divider will suffice as a simple attenuator, however an op-amp with fractional gains may provide better impedance characteristics.
You could visit the following link to find a board that fits your range:
http://sine.ni.com/nifn/cds/view/main/p/sn/n11:7601,n36:19/lang/en/nid/1036/ap/daq
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,723 Views)
Dear Adnan Z,
Thanks for your email.
We will be considering the use of op-amp as suggested by you to reduce the voltage input range. However no board for this input range seems to be available with NI.
Shourya
(3,702 Views)
If the transducer is not already referenced to ground (i.e., it is floating), then you could refer it to one of the board's analog outputs, which you could set to +10V.  Then the output of the transducer would be -2 to -18 volts with respect to +10V, or ±8V with respect to ground, and you could measure it directly with the board.
Can you share more about the transducer?  Do you have a manufacturer name and model number?
Chris
(3,695 Views)
Dear Chris,
Thanks for your idea. Yes it seems to be a good Idea to connect +10 Volt output to referance for reducing the effective gain.
The sensors are Eddy Current Proximity probes which are indeed floating. Please see the attached Manual.
Shourya
(3,678 Views)
