trigger on both rising and falling edge of a digital signal
Hi
I am using USB6259 . There is digital enable signal being used to start  acquiring the analog signals . I wanted to acquire the analog signals only on  rising edge and falling edge of the enable signal . Is it possible ?
regards
AVINASH
(5,077 Views)
Have you tried using this DAQmx VI:
(5,058 Views)
You may also find it useful to look at the
Acq&Graph Voltage-Int Clk-Dig Start.vi
example VI included with LabVIEW
(5,056 Views)
Hi
I wanted to trigger at both rising and fall edge edge not just rising OR falling edge. Is it device specific ?
regards
AVINASH
(5,039 Views)
 Its the device limitation.
http://forums.ni.com/ni/board/message?board.id=70&message.id=11195&requireLogin=False
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(5,026 Views)
