06-28-2023 12:31 PM
I have a NI cDAQ-9174 and Vector CANape. I'd like to add the signal read from NI cDAQ to the CANape interface, so I can monitor the CAN signal and analog signal(from cDAQ) at the same time.
Here is the very basic test, I'm feeding a sinewave to the cDAQ. NI MAX shows the signal is readable, but once I add it into CANape. It shows the error below "NI-DAQmax:Task mode not supported -a0_voltage-".
Does anyone know the reason?
02-16-2024 08:27 AM
Did you got the solution?
Can you tell me how to access 9211A NiDAQmx in Vector Canape
01-31-2025 03:11 AM
with drivers NI-DAQmx 2024 Q4 patch1 : ni-daqmx_24.8.1,
I have a similar problem, you can read from minute 18'18'' for a partial answer :https://www.hbkworld.com/en/knowledge/resource-center/recorded-webinars/webinar-canape-with-hbm-quan....
Good Luck
