Reading multiple distinct samples from a single channel line on python
Hello. I am new to NI. I have 4 channels and I am writing 2 values per channel and trying to find a way to read those 2 values for every channel on PYTHON. But instead, I am only reading the first element in the list-in-a-list for every channel. Hence the 2nd element isn't output'd. May I know how should fix this?
On a separate question, how should I conduct a test to check the quickest time for the machine to read/write values? I would like verify against the specification sheet (I have a NI USB 6289)
Code:
import nidaqmx
from nidaqmx.constants import TerminalConfiguration
# Create a task for the analog output channels
task= nidaqmx.Task()
task.ao_channels.add_ao_voltage_chan("Dev1/ao0", "")
task.ao_channels.add_ao_voltage_chan("Dev1/ao1", "")
task.ao_channels.add_ao_voltage_chan("Dev1/ao2", "")
task.ao_channels.add_ao_voltage_chan("Dev1/ao3", "")
task.start()
nested_list = [[2,3], [4,5], [6,7],[10,8]]
task.write(nested_list,2)
# Create a separate task for the analog input channels
task1= nidaqmx.Task()
# Note the writting style. It is important.
task1.ai_channels.add_ai_voltage_chan("Dev1/ai0","",terminal_config=TerminalConfiguration.RSE)
task1.ai_channels.add_ai_voltage_chan("Dev1/ai1", "",terminal_config=TerminalConfiguration.RSE)
task1.ai_channels.add_ai_voltage_chan("Dev1/ai2", "",TerminalConfiguration.RSE,-10,10)
task1.ai_channels.add_ai_voltage_chan("Dev1/ai3", "",terminal_config=TerminalConfiguration.RSE,
                                      min_val=-10, max_val=10)
task1.start()
value1 = task1.read(number_of_samples_per_channel=1)
print(value1)
task.stop()
task.close()
task1.stop()
task1.close()
Output: [[2.99981258877711], [4.999941758700331], [7.000392949796307], [8.000182112088945]]
(546 Views)
Hello!
The device cannot write 2 values to the same channel at the same time. You need to write the values, then read the values, and repeat.
For instance, you will need to write the first 4 values to the 4 AO channels, then read the values. After that, write the last 4 values to the 4 AO channels and then read again. The output will be 2 lists of your read values- you can combine these into one if you want. If you use the “with” statement, you don’t need to stop and close the tasks.
For code timing, you can check here.
import nidaqmx
# write output voltage to each channel
# you can't combine multiple writes in one task
with nidaqmx.Task() as task:
    task.ao_channels.add_ao_voltage_chan("Dev1/ao0")
    task.write(2)
    task.ao_channels.add_ao_voltage_chan("Dev1/ao1")
    task.write(3)
    task.ao_channels.add_ao_voltage_chan("Dev1/ao3")
    task.write(4)
    task.ao_channels.add_ao_voltage_chan("Dev1/ao4")
    task.write(5)
# read AI channels - outputs to list1
# you can combine multiple reads in one task
    task.ai_channels.add_ai_voltage_chan("Dev1/ai0",terminal_config=TerminalConfiguration.RSE, min_val=-10, max_val=10)
    task.ai_channels.add_ai_voltage_chan("Dev1/ai1",terminal_config=TerminalConfiguration.RSE, min_val=-10, max_val=10)
    task.ai_channels.add_ai_voltage_chan("Dev1/ai2",terminal_config=TerminalConfiguration.RSE, min_val=-10, max_val=10)
    task.ai_channels.add_ai_voltage_chan("Dev1/ai3",terminal_config=TerminalConfiguration.RSE, min_val=-10, max_val=10)
    list1 = task.read(number_of_samples_per_channel=1)
# repeat with remaining values
    task.write(6)
    task.write(7)
    task.write(8)
    task.write(9)
# list2 is new values
    list2 = task.read(number_of_samples_per_channel=1)
print(list1, list2) ​
(520 Views)
