Readings in a loop using USB 6003
I'm trying to inject a signal and read 2 voltages using the analog output and input portsof USB 6003 using LabVIEW.  I use the digital I/O to control relays to move the signal to different points in my test circuit.  When I run this through once, it works fine.  The problem comes when I try to run my VI in a loop.  It makes the readings I tell it to for the first point, but when it loops I get an error saying the buffer needs more time (or something to that effect).  So, what am I doing wrong?  How can you clear the buffer?  I've attached my VI's, Test2A is the main VI and CurveTrace is the sub.
Message 1 of 1
(4,364 Views)
