data acquisition Hardware
Hi ,
I have a harware requirement can some one suggest me a hardware for following Specs
No of Channels : 24
Input type : single ended as well as differential
ADC resolution : 16bit minimum
Sampling rate : 200kS/s minimum
Coupling AC & DC this is should be configurable.
Please suggest me hardware as early as possible
Thanks in Advance
(4,497 Views)
I would highly recommend giving your local NI representative a call.  They can help you a lot better in person than we would over the internet.
The AC/DC coupling could be an issue.  The rest look like standard specs for a DAQ board.  Maybe you should give a good look: Data Acquisition (DAQ)
(4,493 Views)
