fpga-USB-RIO Analog Output voltage mode
Hi to all
i just got usb-7855
i am useing its analog channels for a project. as in datasheet, its range is from -10 ot +10.
is there is any way so that i can use it from 0 to 20V. my aplication dont require -ve volts..
is there any way to use single analog output from 0 to 20V
(4,177 Views)
Hello Naveed,
There is no way to change the range outside of the supported range through software.  You can create an external circuit to add a DC bias to your analog inputs and outputs in order to shift your range to what you desire.
Thomas C.
FlexRIO Product Support Engineer
(4,141 Views)
