05-30-2008 05:03 PM
06-02-2008
05:25 PM
- last edited on
03-12-2025
02:46 PM
by
Content Cleaner
Hi JP,
It sounds like you have done a good deal of background research. However, the module which you are chosen may not be the best option for you. RTD's require additional signal conditioning such as an excitation current. While it is possible to provide this externally, you may want to consider the RTD modules available in SCXI or CompactDAQ form factors. A PXI digital multimeter/switch system may also be a viable option for you. For more information on using RTDs, you can look at this article. Once the data is acquired, you will be able to display the data in a graph indicator and use File I/O functions to export the data in files which can be opened in Excel. If you have additional questions, feel free to call a technical representative or post back.
Kent
06-05-2008
08:15 PM
- last edited on
09-21-2026
05:49 PM
by
Content Cleaner
Message Edited by JPNaidu on 06-05-2008 08:16 PM
06-09-2008
09:23 AM
- last edited on
09-21-2026
05:49 PM
by
Content Cleaner
Hi JP,
I'm not quite sure what your requirements are for your application but this module will work if you wanted to set programmatic voltage setpoints for each individual element. If this what you need, you may also want to consider the NI 9264 to pack more channels into a module. As for your second question, this can be easily done in LabVIEW. If you have LabVIEW installed already, there are good examples for this in the Example Finder which can be accessed in the Help menu. One good example for your application may be PID Control-Single Channel.vi which can be found browsing by task under Hardware Input and Output » DAQmx » Control » General. If you are interested, there is also a PID toolkit available for LabVIEW. More information on this can be found here.
Kent
