Regenerate sine-wave from sampling
Hi!
I need to sample three 10kHz sine-waves, using three different analog inputs on my NI USB-6229. Since the total maximum sampling rate is 250kS/s, that should give me approximately 80kS/s per signal. When I display the sine-wave in LabView with 80kS/s, the curves are very rough. Is there any way to manipulate the samples back to the fine sine-wave I read from my scope? It should be possible, considering the samplingrate is 8 times the frequency of the signal.
Børild
Message Edited by HossIsAlright on 02-05-2008 04:44 AM
Message 1 of 1
(2,845 Views)
