Relay recommendation for controlling 5v DC laser from mydaq
I need to control the on off cycles of a basic 5v 50mW laser via my myDaq. I found a tutorial on the NI website wich recommended a certain solid state relay from cycling the power of a 12v fan, but that relay is no longer available. Does anyone have a recommendation of where I should look?
(4,569 Views)
Hello Aboyd656,
Please could you give more information on the NI website tutorial, and which relay it recommended? To see which other product we can recommend you.
Daniel M.
Applications Engineering
www.ni.com/support
(4,534 Views)
(4,520 Views)
ONe way:
Go to digikey
http://www.digikey.com/product-search/en/relays/solid-state-relays
and filter for voltage input and output type
order or select a type and search the web for a distributor of your choice.
Greetings from Germany
Henrik
LV since v3.1
(4,516 Views)
