Requesting a code for superposition theorem
Hii.....every one..
i recently started implementing the circuit for verification of superposition theorem on the ni elvis prototyping board with labview 8.5.1.....so am not getting the measurement of current and generating the digital output how i can do that??
in the ni.com site in the link http://zone.ni.com/devzone/cda/tut/p/id/4469 given the super position theorem.............for that can anyone send the labview code for verification of superposition theorem.............plzzzzzzzzzzzzzzz
i have to acquire the voltage and current into the one table with different sources enabled.........plzzzz send me some demo pgm code.......plzzz
thank you.......
(4,423 Views)
Do you get an error notification when you attempt a digital output/ current input operation? If yes, then what is the error code and message?
If not, then can you explain the problem in a little detail? How have you made your hardware connections and what exactly are you doing on the software side?
Vaibhav.
(4,403 Views)
hii...........
i have generated the digital signals to the prototyping board from PC but when i measure on the board it is not showing anything. On the PC it is showing the generated digital output.
Whereas about current..... how can i measure the current on the prototyping board. I am measuring the voltage across any element in the ckt which is on the board which is working whereas the current measurement is not working.........so how i have to measure current...?
Thank you...
(4,392 Views)
