Retriggerable DAQ - samples missing
ceties,
Ah... Yes... if you read 8004 samples, and throw away the first 4 each time, you should be left with 8000 valid samples.  I assumed that you were only going to be throwing away the ADC's pipeline depth worth of samples which would have been 3.  It sounds like you've got a good handle on everything!
Best of luck with your application,
Dan
Message 11 of 12
(1,102 Views)
Thanks again Dan for your advices!
LV 2011, Win7
Message 12 of 12
(1,099 Views)
