Route the ATCOut to a digital line
I'm using a hardware analog trigger connected to the PFI0, and i need to route the ATCOut signal to a digital line, how i do this? Thanks in advance. If possible with example.
(2,717 Views)
Though you cannot route this signal to one of the eight DIO lines, you can indirectly route it to a PFI line though which will probably function just as well for you. In fact, here is a LabVIEW example that does just this.
Using the Analog Trigger Circuitry Output as an External Signal
I'm not sure if you're using LabVIEW or not, but if not you should be able to get a good idea about what is going on from the description.
I hope this helps.
Russell
http://www.ni.com/support
(2,717 Views)
Yes, i'm using labview 6i and a DAQ Card PCI-MIO-16E-4. I'm tryin to first route the ATCOut signal to a PFI line and then connect physically this line to a digital line for polling it. But i don't know how to do this. Thanks.
Greetings
(2,717 Views)
Yes, the LabVIEW example I mentioned should do the trick. You actually have to route the ATCOUT signal to an intermediate location such as a counter gate first and then route that to a PFI line. The example covers this.
Then you can physically wire the PFI line to any digital line for polling. Check your user manual for a pinout of the PFI lines.
Russell
(2,717 Views)
