Routing analog input/output to/from PFI
i would like to measure and generate analog signals. Best would be if i could route the signals from or to the pfi-terminals. Is this possible? Or is routing only for digital signals.
Thanks forward
Andreas
(2,848 Views)
Andreas,
on multifunction DAQ boards you can only route digital signals. If you need flexible routing for other types of signals, you should look into switching solutions.
Kind regards,
Jochen Klier
(2,833 Views)
