specified resource is reserved. operation could not be continued as specified
well i need to generate two analog outputs continuously with USB 6211.
one is a sine wave at ao0 and the second one a delayed square wave wrt to sinewave at ao1output.
is this going to be possible? vi enclosed for suggestions.
thanks
(2,729 Views)
You could have searched the forum for the error code you are gettings. It's a very common mistake. You need to use a single task. That measn you use a single DAQ Assistant and specify multiple channels.
(2,720 Views)
