Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
specified resource is reserved. operation could not be continued as specified
mpsarma1
Member
06-11-2008
04:42 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
well i need to generate two analog outputs continuously with USB 6211.
one is a sine wave at ao0 and the second one a delayed square wave wrt to sinewave at ao1output.
is this going to be possible? vi enclosed for suggestions.
thanks
mp_sarma@yahoo.com
mpsarma1@gmail.com
mps1.vi 232 KB
0
Kudos
Message
1
of 2
(2,733 Views)
Reply
Re: specified resource is reserved. operation could not be continued as specified
Dennis_Knutson
Knight of NI
06-11-2008
08:24 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You could have searched the forum for the error code you are gettings. It's a very common mistake. You need to use a single task. That measn you use a single DAQ Assistant and specify multiple channels.
0
Kudos
Message
2
of 2
(2,724 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
