SCB-68 Requirements and Compatibility
Currently running Windows 7 with SCB-68. Looking to upgrade OS to Windows 10. Is SCB-68 Compatibility with Win 10 OS?
(2,735 Views)
I would imagine you will be fine with the SCB-68, it does not depend on the operating system because it is just a connector block.  You will need to know the device in your computer that is connected to the SCB-68 and see if it has compatible drivers for Win 10.
(2,732 Views)
Thanks for the reply. Agreed. The card used is NI PCIe-6361. Is this card compatibility with Win. 10 OS?
I will be researching parallel to this post. TIA
(2,722 Views)
Go to: https://www.ni.com/en/support/documentation/compatibility/21/ni-hardware-and-operating-system-compat... and enter your card and it will give you compatibility information.
(2,707 Views)
