pci-1710 driver
I would like to ask why I installed the driver of the PCI-1710 Advantech capture card, but I can't find the relevant controls in the Labview user library. Why?
Thank you!
(2,435 Views)
Thank you!
My first thought would be to contact Advantech.  I have used a digital IO device from Advantech and found it confusing at first.  Did you read ALL the documentation for the drivers, they are not as simple and straight forward as using a NI card with MAX.  I just looked and the drivers for the DIO are in the measurement IO palette.
Take a look at this as well:
http://advdownload.advantech.com/productfile/Downloadfile1/1-12ZIULS/FAQ_DAQNaviAssistantViInLabVIEW...
(2,399 Views)
