Multifunction DAQ
SCB100
Hello.
I would like to know if there is any instruction manual or something helpfull to start aquiring data from a signal generator. I'm new in this topic and I'm supposed, as I said, to aquire data from a signal generator using a PXI1002, a SCB100, and a BNC2110. I'm so lost that I don't even know how to plugg them,
Thank you
Pablo
(3,724 Views)
Your message says what chassis and connector blocks you have, You need to know what cards are in the PXI chassis. Remove the connector blocks and the faceplate will have the card number on it. Look the card up on ni's web page. that will give you the pinout.
Greg Bush CLAD
(3,716 Views)
As Bushman said, you need to know what type of card you have in your PXI chassis. In addition, your products came with manuals and those manuals will work you through the setup process. Once you have setup your system, you can search www.ni.com for tutorials and examples to run on your sytem.
I would also recommend considering classes offered by National Instruments. You can check them out at http://www.ni.com/training/.
Hope it helps.
(3,711 Views)
