Multifunction DAQ
SCXI-1001Does not Read properly
Hi Adam,
It appears that you have done quite a bit of troubleshooting on this particular chassis.  If you have already followed the steps in the Troubleshooting SCXI Chassis  KB, replaced the 1346, fuse and cables and verified that the problem stems from the chassis then my suggestion is that you send it into NI for repair
Message 11 of 11
(695 Views)
