01-23-2012 10:43 AM
Hello we are trying to connect the SHC68-68-epm to a right angle PCB mount connector. First we don't know what threads the jack screw uses in this cable. I suspect M2? Our PCB connector has M2.5. Does NI have a compatible PCB connector with standoffs so that we can screw these cables in or are there replacement jack screws supporting M2.5. What connector is used in the terminal block?
01-24-2012
08:47 PM
- last edited on
03-06-2025
10:51 AM
by
Content Cleaner
Hi johngardner58,
According to the KnowledgeBase article "Screw Sizes for M Series Connectors" it looks like the SHC68-68-epm cable uses screws of size 2-56 UNC-2A. A 68-pin terminal connector that can be used with the SHC68-68epm cable for making custom mounts can be found on the "PCB Mounting Connectors" page.
