Sampling rate of 5133
I read the manual and get as below, it seems the sampling rate varies continously. But normally the sampling rate varies discontinously as step by step.
Any suggestion?
Internal sample clock frequency ........
100 MS/s
(USB-5133) sampling rate with
decimation by n, 1 < n < 65,535
Message 1 of 9
(4,211 Views)
Since you don't explain your problem clearly, I guess you wish to know available sampling rate of 5133.
Well, its maximum is 100 MS/s, and you can divide it by integer to get a lower sampling rate down to 1.526 kS/s which is 65536 division.
Message 2 of 9
(4,195 Views)
If this is really true, does that means the config of the data length of collection may not be very accurate.
Message 3 of 9
(4,184 Views)
Why do you think it's going to be in accurate?
Could you please share your idea in detail so that I can explain to you?
Message 4 of 9
(4,182 Views)
I need to config the exactly the wave length for data processing and storage.
Such as each wave 100 points or points.
Message 5 of 9
(4,147 Views)
Then, just configure Record Length to 1000 points.
I don't see anything concern with sampling rate.
Message 6 of 9
(4,142 Views)
The sampling time period is fixed, when user change the sampling rate, I need to know the exact number of sampling points.
Message 7 of 9
(4,140 Views)
Then, you can divide sampling period by actual sample rate property of niScope to find out what is an actual record length you should have.
Message 8 of 9
(4,138 Views)
Hi Everybody,
Thanks for the suggestions Kate!  You can also read back the Actual record size directly through the niScope API--in LabVIEW it can be done with an niScope Property Node:
If you were looking for something else don't hesitate to let us know.  I hope this helps.
-John
Message Edited by John P on 12-01-2009 07:25 PM
John Passiak
Message 9 of 9
(4,123 Views)
