Screw Terminal Blocks - SCB-68/100 - can't get them to function
A while back I was trying to utilize a SCB-68 connector block with a PCI DAQ card, and I couldn't get it to work properly. I have used DAQ racks and other boards before with no trouble, so i was a bit perplexed. So i just used an older DAQ board and moved on to something else. Now I am trying to use the SCB-100 in a different setting, and again I am having troubles. So perhaps someone could direct me out of my ignorance in using these blocks. Using instrumentation explorer, I have tried using the test panel for Digital I/O. First of all, the test panel shows 31 digital I/O selects, and that is all. Secondly, because the online manual (don't know where original is) doesn't indicate which pins are which on the block, i have no idea which pins these 31 selects correspond to. Finally, I tried measuring all outputs of the card on the block for a TTL signal, but all were low. So, I'm pretty stumped. Suggestions anybody?
(3,026 Views)
The pin configuration of SCB68/SCB100 depends on the card used.
Check the manual for the card and look at the pin assignment. They are the same whether you use SCB68 or CB68LP/LPR, etc.
for example a PCI- Eseries manual should list the pin configurations for all PCI MIO cards.
Many MIO cards have identical pin assignements (except for the availabity of extra output channels and more DIO's.
(3,019 Views)
