Self-calibrating the Daqcard 6024E
I find I can self-calibrate the Daqcard 6024E using NI-DAQmx. Is this calibration still valid when I then select  "Traditional NIDAQ configuration?
(3,557 Views)
I don't think that Traditional DAQ has this option.  Traditional DAQ hasn't been supported in so long, so unless you are absolutely stuck with it I recommend upgrading to DAQmx.  It is a much better API too.
(3,552 Views)
THanks for your reply.
Yes, I kinda am stuck with it afor the time being. Having said that, if I self-calibrate in NI-DAQ max config. can I be assured that the calibration holds truefor Traditional Config?
(3,548 Views)
Accepted by topic author jeipower
I'm pretty sure the self-calibration uses coefficients that are stored on the card.  Therefore, it should stick.
I would still recommend sending it out for professional calibration once a year to make sure the built-in standard is still good.
(3,544 Views)
Thanks, will do.
(3,540 Views)
