Send serial data
Hi
i use compacDAQ chassis with ni9401 module and i would like to send serial data on one line with a frequency about 100kHz.
Now i can send serial data using a for loop but the frequency is limited, only 10-50Hz.
(3,207 Views)
Your module can send at a 20Mhz on 2 lines ... So I think it's possible. But you will not be able to treat the information at this rate.  I don't really know what you want to do ... Could you post your VI ?
Richard Keromen
(3,173 Views)
