Setting input and output range and gain for USB 6259
What are the allowed input and output ranges to chose from with the USB 6259? Where is this information on the website?
thanks
(2,922 Views)
Hi Bill-
The NI 625x Specifications include this info.  They can be found from the USB-6259 product page.  You can also query this information programmatically, either from the DAQmx Device Property Node (LabVIEW) or the DAQmxGetDevAIVoltageRngs() and DAQmxGetDevAOVoltageRngs() (C API).
Hopefully this helps-
Tom W
(2,919 Views)
