Setting nominal voltage?
It should behave for the biggest part the same as the DAQ Assistant in LabVIEW.
The only thing you'll have to keep track off are the supported ranges of your card itself.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 13
(996 Views)
I only have a license for SignalExpress so I cannot compare. But I also tried using the hardware in a C# program so it's good to know some details.
And completely offtopic: very snowy isn't it? 😉
Message 12 of 13
(991 Views)
Yes,
Very snowy!
I didn't even get to the office, so I just worked from home 🙂
Kind Regards,
Message 13 of 13
(980 Views)
