Hello!
You can read from multiple analog input channels and at the same time perform output operations as well as perform digital I/O and counter operations.
The speed with which you can perform these actions are dependent on the board you are using (read number of available DMA channels) but the driver itself is multithreaded and supports this.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
