Signal conditioner to computer
I have a few piezoelectric accelerometer sensors connected to a signal conditioner. Now I need to get the data onto matlab for processing. What product is best for data acquisition from a signal conditioner to a computer? I need at least 8 channels.
(2,234 Views)
Accelerometer assumes a minimum bandwidth (max frequency you measure) .
Typical output ranges of the signal conditioners is +-10V
If you want to do modal or whatever comparing signal analyses, you want a synchronious data aqisition ...
I would look for a 8 channel synchronious DAQ. If mobility is needed maybe USB?
DAQmx is supported by matlab AFAIK.
Pick up the phone and talk to NI ... they migth have some more questions....
Greetings from Germany
Henrik
LV since v3.1
(2,184 Views)
