Multifunction DAQ
Simulate input
  To verify my software, I would like to simulate some signals on the input of the NIDAQmx simulated board. Is it possible ?
  I have created the simulated board in NI MAX, but I does not know how to simulate signal on the inputs and run my software (in C langage) to acquire the data.
(5,948 Views)
When I have made simulated devices, doing a scan of analog inputs gets you data in the form of a noisy sine wave. I can't recall what happens if you read digital inputs.
Outputs don't do much 🙂
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(5,927 Views)
Accepted by ChristophePo
The input signal of a simulated device is predefined, you cannot change it. It is much better to write your own piece of code that would simulate the signal.
(5,901 Views)
Ok thanks !
(5,898 Views)
But while you are here, go give this idea a Kudos: Interactive DaqMx simulation interface
(5,895 Views)
