Small NIDAQ ANSI C API Vista Driver
Is there a small NIDAQ ANSI C API Vista Driver for USB 6211 available?
Peter
(3,824 Views)
Hi Peter,
I see you are asking about NI-DAQ support for your USB-6211. I am assuming you are referring to NI-DAQmx. Do you need a smaller driver for deployment of an application or an actual development environment? If you are developing in ANSI C you will need the full download of DAQmx 8.5 or 8.6 since a lot of the code is shared between different development environments.
If you only need to deploy your application we do have five different footprints available for the DAQmx run-time. Currently these are not yet available online for DAQmx 8.5 and 8.6. I have included a link below to a page which describes the footprint options available.
What's New in NI-DAQmx 8.6
Chris Behnke
Sr. RF Engineer
High Frequency Measurements
(3,806 Views)
The install of selecting only the ANSI C option in DAQmx uses 600MB of disk space. It is an overkill to have access to the 600kB ANSI C library. I am not interested in 30 day demos or any LabXXX stuff for either development nor deployment. When can we expect to see the RT versions?
Peter
(3,787 Views)
Hi Peter,
We will be addressing and releasing the smaller run-time footprints of DAQmx 8.6 in the near future. There is another post which I have linked below that deals with this same topic. An official update to this issue will be posted on this linked forum when the real-time footprints are available online.
Where do you hide the runtime engines for DAQmx?
Just to summarize once again, these smaller footprints are run-time engines only and will not allow you to develop new applications in C. You will only be able to deploy and run previously developed applications. If it is your intention to develop in C you will need the full version of DAQmx 8.6.
Chris Behnke
Sr. RF Engineer
(3,645 Views)
I am switching back to XP and found NIDAQ830RTE5.zip so I am all set for now.
Thank you,
Peter
(3,639 Views)
