Multifunction DAQ
Speed of AC RMS Measurement with Lab View controlling NI USB-6008 DAQ
Dear Board,
I am attempting to control a motorized Variac's output voltage using a couple of relays for up and down control, actuated by an Agilent 34970A. I sample the variac voltage through a transformer, and use a lab view program to measure AC RMS volts and compare the measurement to an input command to regulate the output by actuating the relays. I have a 3 volt window programmed, with overshoot and undershoot compensation. The program works, but is not nearly fast enough, as the output swings some 50V or so, around the command voltage. I was thinking that the rate of AC measurement is a key. I also have not tried it in .exe format. Would that make it faster, or is it a function of the speed of RMS measurement? Would another DAQ, like the NI USB-6008 help? Thank you for any insights.
Sincerely,
Mike
(3,008 Views)
Hello Mike,
Thank you for your interest in National Instruments Data Acquisition products. For more information on performing basic RMS calculations in LabVIEW check out the Developer Zone Example: Basic DC-RMS Measurements.  In terms of choosing a data acquisition device the main thing that you will need to be careful of is the voltage specifications of the device you are considering.  For your application the USB-9229 would work very well, as it can handle ±60 V DC signals and has an acquisition rate of 50 kS/s per channel.  This should give you the voltage swing you need along with a more than sufficient sampling rate.
Dan King
(2,974 Views)
