Standalone solution with NI 9205 and cDAQ9171
good luck then. Happy to hear that this should work. let us know if it really does 🙂
Anna Vogl
Certified LabVIEW Developer
Message 11 of 12
(1,643 Views)
Hi Martin :
Initially, you wanted to use
cDAQ9171 with USB connection combined with the NI9205, but later you decided to go with other Ni module due to some issue.
I am interested to know which NI module you utililize finally. Can you please share your experiences how you acquired signals, sampling rate? Did you use DAQ Mx?
i want to discuss with you more, what is the best way to reach out?
thank you,
DP
Message 12 of 12
(485 Views)
