Multifunction DAQ
Stop WFM_Op indefinite output?
How does one stop a WFM_Op call with "iterations" set to 0 (run indefinitely)? I can't seem to find instructions on how to do this.
(2,541 Views)
Instead of WFM_Op, you should use low-level functions for analog output :
WFM_Load (to load your signal into the generation buffer)
WFM_Group_Control with operation set to OP_START (to begin generation)
WFM_Group_Control with operation set to OP_CLEAR (to stop generation)
Hope this helps.
BMN
(2,541 Views)
