Suggestion of NI DAQ card with at least 64 AI and compatible with the BNC-2090A connector block for all channels
I have a PCI 6031E (64 AI, 2 AO, 16 bits, 100 kS/s) connected to 3 BNC-2090(A) connector blocks using the SC-2056 cable adapter.
I'd like to have a higher sample rate but I am unable to find a daq card with at least 64 AI and compatible with the BNC-2090(A) for all channels.
The 6225 DAQ does not seem to work with only BNC-2090A blocks.
Does anybody know a NI DAQ card with at least 64 AI and compatible with the BNC-2090A connector block for all channels?
thanks in advance
Marcos
(3,837 Views)
You can check this out: http://www.ni.com/pdf/manuals/321183a.pdf It's the manual of the BNC-2090. You will find out the connections that are better suitable for your applications in page 2-8.
Search in the website models of hardwares based on your requirements: http://www.ni.com/solution-designer/
You can also contact the Sales department where they can better suggest you which hardware is better for your needs.
gfavaron
(3,813 Views)
