System error 50502 using PXIe 6368 Cards with PXIe 8880 controller
Hi all
I am using 07 PXIe-6368 DAQ Cards with PXIe 8880 Conroller (8 GB RAM) installed in PXIe-1078 chassis for simultaneously acquiring 100 channels data in finite mode (with Trigger mode Enable  ) with maximum sampling rate i.e. 2 M samples/s/channel. I am currently using NI DAQmx ANSI C routines to acquire this data.
The problem is that i want to simultaneously acquire 0.45 sec data for each analog input channel for each trigger pulse it receives. This requires about 900 K samples/channel to be acquired for every trigger pulse. However, the program gives an error (status code: 50202) that operation can not be completed as specified. Below 600 K samples/channel, this program works fine however this does not fulfill my requirements.
With PXIe-8880 controller (8-core processor) installed with 8 GB RAM, 250 GB SSD and PXIe-1078 chassis, is this required acquisition is more than the capacity of this  system or there is something i can do in my C programming using some C APIs to enhance the performance of my system?
Thanks & Regards
(3,326 Views)
In this forum someone asked about a similar issue with that error, you can take a look at the solution described there.
https://forums.ni.com/t5/Multifunction-DAQ/Error-50202/td-p/797498
(3,279 Views)
Hello
Thanks for help but this link you mentioned is not working
(3,267 Views)
Hello ChristopherBrenes
Can you kindly share again this link as i am unable to open this link?
(3,251 Views)
It looks like it is not working, but I found another forum that may be useful for you.
https://forums.ni.com/t5/LabVIEW/What-is-causing-error-50202/td-p/1763466
(3,243 Views)
Hi
Thanks for help. I think the problem is not in coding (may be i am wrong) as i have created a task in NI MAX with these acquisition specifications (mentioned in my first post) and when i try to run this task, it crashes.
(3,239 Views)
Hi all
The problem is still pending and i am unable to solve this issue. Kindly help me.
(3,199 Views)
