Why Two PXI-6281 Aquire One Sensor,Data are Very different
I has a press sensor(-2~2V)->(-60KN~60KN);
Use tee connect two PXI System(PXI 1045+PXI 6281)
Occasionally,I get data waves very different.
Can explain it。
below is two PXI System waves data plot at a graph.(rate = 100kS/s)
(2,279 Views)
The differences in the signal look symmetric, so I would assume a unwanted current in a sensor line, resulting in a voltage drop that adds for one channel and subtracts on the other.
How are the sensor and the PXI systems connected in detail (incl. Powersupply) ? (every wire!)
Do you use other channels of the 6281?  DOes it correlate with other IO ?
Greetings from Germany
Henrik
LV since v3.1
(2,255 Views)
谢谢您的回复,出差刚回来
(2,206 Views)
