Digital Trigger for PXI6289
I am trying use a digital trigger to start a continuous digital output.  I am using the PXI-6289 and my starting point is the example program "Digital - Continuous Output.vi" from NI.  I cannot find a configuration of this example that actually allows the digital trigger without error.
Error -200452 occurred at Property Node DAQmx Trigger (arg 1) in DAQmx Start Trigger (Digital Edge).vi:3930002->Digital - Continuous Output.vi
Possible reason(s):
Specified property is not supported by the device or is not applicable to the task.
Property: Start.TrigType
This example is described as being for the PXI6289 - not quite sure where to start while debugging this issue.
Thanks!
Paul
Message 1 of 1
(2,050 Views)
