buffered counter output fails on x series
I am using x series multifunction DAQ (NI 6368). I would like to do counter output with buffered sample clock timing. However, it keeps throwing this error:
DAQmx Error: Generation cannot be started, because the selected buffer size is too small.
Increase the buffer size.
Conflicting Property
Property: DAQmx_Buf_Output_BufSize
Corresponding Value: 0
Minimum Supported Value: 2
Channel Name: Dev1/ctr0
Task Name: _unnamedTask<0>
Status Code: -200609
What could be wrong here?
I get this error either from my program, or even from the DAQmx C example code. For reference, here is the code in DAQmx example that throws the bufsize error:
"C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Counter\Generate Pulse\Dig Pulse Train-Cont-Buff-Ext Clk\DigPulseTrain-Cont-Buff-ExtClk.c"
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData);
#define DUTY_MIN	0.50
#define DUTY_MAX	0.80
int main(void)
	int         error=0;
	TaskHandle  taskHandle=0;
	int32       i;
	float64     dataFreq[1000],dataDC[1000],dutyStep;
	char        errBuff[2048]={'\0'};
	// Generating data for duty cycle from 0.50 to 0.80 in 1000 steps
	dutyStep = (DUTY_MAX-DUTY_MIN)/1000;
	for(i=0;i<1000;++i) {
		dataFreq[i] = 1000.0;
		dataDC[i] = DUTY_MIN + dutyStep*i;
	// DAQmx Configure Code
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateCOPulseChanFreq(taskHandle,"Dev1/ctr0","",DAQmx_Val_Hz,DAQmx_Val_Low,0.0,1.00,0.50));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"/Dev1/PFI0",200,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
	DAQmxErrChk (DAQmxWriteCtrFreq(taskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,dataFreq,dataDC,NULL,NULL));
	DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
	// DAQmx Start Code
	DAQmxErrChk (DAQmxStartTask(taskHandle));
	printf("Generating pulse train. Press Enter to interrupt\n");
	getchar();
Error:
	if( DAQmxFailed(error) )
		DAQmxGetExtendedErrorInfo(errBuff,2048);
	if( taskHandle!=0 ) {
		// DAQmx Stop Code
		DAQmxStopTask(taskHandle);
		DAQmxClearTask(taskHandle);
		printf("DAQmx Error: %s\n",errBuff);
	printf("End of program, press Enter key to quit\n");
	getchar();
	return 0;
	int32   error=0;
	// Check to see if an error stopped the task.
	DAQmxErrChk (status);
Error:
	if( DAQmxFailed(error) ) {
	return 0;
(2,406 Views)
I Googled that error code and found this article:
Error -200609 When Using NI-DAQmx Output Tasks
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7jnSAC
Down at the bottom it talks about the output buffer size which sounds like it applies to what you're seeing.
(2,367 Views)
