Multifunction DAQ
Take N samples M times before sending to disk - NI-USB
Hi there,
I have a NI-USB 6259 DAQ, and I am wondering if it's possible to take N samples M times (with M triggers) before sending the data to disk. In other words, can I set the number of samples N to be finite, and have the DAQ waiting for M triggers, and after M triggers where the DAQ collects N samples each time (at some rate) it sends the accumulated data to disk?
(2,501 Views)
Accepted by chadt
Hi chadt,
Here is a forum post that may be helpful to you.
Finite Retriggerable Analog Input Using LabVIEW with DAQmx
https://forums.ni.com/t5/Example-Programs/Finite-Retriggerable-Analog-Input-Using-LabVIEW-with-DAQmx...
You can create a stop condition or use a for loop so it only executes M times.
sarahmo
(2,468 Views)
