Test panels not opening
I'm running MAX version 5.3.1f0 and using a NI USB-6221 DAQ. I am able to create and run task but the Test Panels will not open. I've have also tried using a NI USB 6009. I also have un-loaded the NI software and re-installed it, still I,m not able to open Test Panels. Any help would be appropriated.
Message 1 of 9
(4,468 Views)
that's strange...can you run it from the command line by running
c:\windows\syswow64\nidmfpan.exe /devid:Dev1
-replace Dev1 with your device name, of course
-it may be system32 if you are not on a 64-bit OS
did you install DAQmx? If so, what version?
-gaving
Message 2 of 9
(4,461 Views)
Message 3 of 9
(4,460 Views)
I was not able to run it from the command line. I did a search for the nidmfpan.exe  and found it at C:\windows\system32. I tried running it from the command line and got the following error:
This application has failed to start because mfc90.dll was not found Re-install the application may fix the problem.
I have tried re-installing MAX. Also I installed NI_DAQmx Device Driver 9.5.5, also NI-DAQmx MAX Configuration 9.5.5
Message 4 of 9
(4,456 Views)
looks like your Visual Studio runtime was corrupted somehow...try downloading and installing one of the 2008 redistributable packages...
https://www.google.com/search?q=2008+redistributable
Message 5 of 9
(4,445 Views)
I down loaded and installed the 2008 redistributable sp1 after un-installing the 2005 redistrubutable package. This didn't fix the problem.
Message 6 of 9
(4,431 Views)
Any update to this?  I am also having a problem with Test Panels in MAX due to mfc90.dll problem.
Dan...
Message 7 of 9
(4,228 Views)
Hi thisisnotadream,
There is a possible solution to this problem in this thread. Let me know if this works for you!
David B.
Message 8 of 9
(4,208 Views)
Found that thread late last night.  Worked!  Thanks for following up!
Message 9 of 9
(4,205 Views)
