cdaq 9171 - ai 9219 error 200019
sorry, but i got this message : "ADC conversion attempted before prior conversion was complete. Increase the period between ADC conversions. If you are using an external clock, check your signal for the presence of noise or glitches." And I don't know what to do.
My configuration is:
LV 2012
cDAQ 9171
AI 9219
What I've done till know:
-changing the resolution
-changing Rate and Buffer Size
-Connection seems to be okay (Test in MAX)
best regards.
Thomas
(3,640 Views)
Hello Thomas,
thank you for using National Instruments Forum.
I want to recommend following Knowledge Base. I hope this workaround will help you.
Why do I get Error -200019 when using my Multifunction DAQ Device?
http://digital.ni.com/public.nsf/allkb/1275F44215D5C13F862579AE006CA222?OpenDocument
Mike
(3,600 Views)
thomasfellner,
Sorry to piggyback on your post.
When I install my 9219 into my 9171 it shows up as an unsupported module "cDAQ1MOD1".
Did you have this issue?
L.V. 2012
DAQmx 9.7
Thank you for your time.
(3,497 Views)
Hi Jeff,
no sorry, my device was simply defective.
i sent it to NI, and they repaired it
bye
(3,494 Views)
Smiley Tongue
My problem was a bent pin (6) down in the cDAQ-9171.
Repaired that and it works!!
Again thank you for your time.
(3,485 Views)
