The device PCI 6036E: Analog Input error:"the device is not responding to the base address",Output :No signal
I am using PCI 6036E DAQ card, DAQ 6.9.2. , I have not connected to any external device.
When I tested card(in Test Panel of MAX2.2,DAQ 6.9.2) an error appearing �the device is not responding to the base address� � then I pressed Yes, Then TestPanel window appearing�
In analog Input Tag, there is an error �-10805�. This error also appearing when I run the standard analog input samples (use Delphi 6.0).
I tested analog output functions in TestPanel, Delphi Examples, LabView 6.1. There are not error appearing but there is not output signal (using Oscilloscope to see).
Output, Input digital functions are working correctly.
Next I try to foll
ow all the instruntions as recommended:
-Changing TO another slots PCI
-Reinstall Os WinXP,98SE�
-Use another Computer�
But all of the cases are still not working.(the above error still appeared, no output signal)
(2,851 Views)
Nvd,
I'm sorry to hear about the problems that you are running into with your DAQCard. I can understand your frustration with the errors that you are seeing. You mention that you have tried to do some troubleshooting, I was wondering if you have tried all the troubleshooting techniques listed in this KnowledgeBase:
http://digital.ni.com/public.nsf/websearch/DCFCDB240788F8D486256D6A00834D80?OpenDocument
If you have tried all of those things, I would suggest one additional thing to try. I would suggest updating your NI-DAQ drivers to version 7.0. These drivers are the newest versions of our Data Acquisition Drivers, and can be downloaded from our website here:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C128D?OpenDocument&
node=132060_US
If you have tried all of the above troubleshooting options, please post a detailed description of what you have tried. This may help to clarify what is going wrong.
Jed R.
(2,851 Views)
